APC Props
What are the most commonly used apc props used today for 428, I know there are a lot of differents ones made, but the ones used more for humid warm air?
RE: APC Props
most guys running Nelsons r using the 8.8x9.25 or 8.8x8.75 and guys running Jetts r using 8.8x9 and 8.75x9w
RE: APC Props
I'm by no means an expert on the subject but it seems the most common prop is the 8.8x9.25... If it's really hot and humid or your engine isn't a real hoarse, then the 8.8x8.75 works well... That's what seems to be the most common that you see on here anyway.
RE: APC Props
The 8.8x9.25 seems to be the fastest, however, most people can't ease off the sticks enough to get the best speed out of it. The 9.25 also is a tricky prop to get a good needle setting for many people. Take some time to practice with it, and a good engine will really haul with this prop. The 8.8x8.75 seems to be the best overall prop for the average racer. Easy to needle, good acceleration, and pretty good top speed.
RE: APC Props
Thanks for the input fellas!:D
| All times are GMT -8. The time now is 10:28 AM. |
