RCU Forums
-   Q-500 Racing (https://www.rcuniverse.com/forum/q-500-racing-149/)
-   -   Clear Coat (https://www.rcuniverse.com/forum/q-500-racing-149/9268744-clear-coat.html)
PylonDave 11-20-2009 09:09 PM
Clear Coat
anybody know if you can Clear Coat with PPg type paint over painters touch rattle can paint???
Stevem9 11-20-2009 10:25 PM
RE: Clear Coat
if its laquer based some ppg clears you can. which one do you have?
Jim_Purcha 11-20-2009 11:02 PM
RE: Clear Coat
<span style="font-size: x-small"><span style="font-family: Arial">The Rust-Oleum Painter's Touch is an "acrylic modified Alkyd Resin". I'm not sure if a laquer could be applied over it. I'm in the same stituation with an almost completed model done with painters touch. I have some clear klasskote at home I might use. Nelson's Hobby Paint has a water based clear coat which is supposed to be odourless.</span><font face="Arial"><font face="Arial">
</font></font></span><font size="2" face="Arial"><font size="2" face="Arial">
Jim
</font></font>
ORIGINAL: PylonDave
Conrod 11-20-2009 11:39 PM
RE: Clear Coat
ORIGINAL: Jim_Purcha
The Rust-Oleum Painter's Touch is an ''a<font size=''2'' face=''Arial''><font size=''2'' face=''Arial''>crylic modified Alkyd Resin''. I'm not sure if a laquer could be applied over it. I'm in the same stituation with an almost completed model done with painters touch. I have some clear klasskote at home I might use. Nelson's Hobby Paint has a water based clear coat which is supposed to be odourless.
Jim
</font></font>
ORIGINAL: PylonDave
Is this paint not fuel proof?
Cheers Geoff
PylonDave 11-20-2009 11:50 PM
RE: Clear Coat
Yes it is fuelproof to a certain amount of nitro. The 15% we use does not hurt it but i want to clear kote to gloss it up some moreand harden the finish to make it more ding resistant. The painters touch chips and dings fairly easy. The clear coat i was thinking of is polyurethane . I don't have it yet. wanted to run it by the forum first.
Jim_Purcha 11-21-2009 12:00 AM
RE: Clear Coat
It was from my understanding that the Rust-Oleum Painter's Touch Brand was not fuel proof at all.
Jim
slim56 11-21-2009 10:50 AM
RE: Clear Coat
I have not tried it but take a look at Minwax Polycrylic at most any hardware store.
Slim
Jim_Purcha 11-21-2009 12:06 PM
RE: Clear Coat
I believe you mean Minwax Polyurethane. I used the polycrylic on the 3/4 oz cloth for surfacing.
Jim
djlyon 11-21-2009 12:41 PM
RE: Clear Coat
I use the Minwax polyurethane clear gloss and it works pretty good over painters touch and ultracoat. Painters touch is about as fuel prof as ultracoat.
OOPS replace ultracoat with LustreKote. LustreKote and Painters touch seem to go on and cure about the same and have about the same prof against 15% fuel.
Denis
slim56 11-21-2009 10:50 PM
RE: Clear Coat
Yes, Jim I think you are correct.
Slim
DMyer 11-22-2009 10:33 PM
RE: Clear Coat
Just get some Klaskote paint and forget about nitro.
I still have some cans of very old K&B (same as klaskote) that I am still using... stuff has a long shelf life.
dan
Jim_Purcha 11-22-2009 11:02 PM
RE: Clear Coat
I have some gloss clear klasskote, but with winter setting in I won't be able to spray the model until at least next April.
Jim
DMyer 11-23-2009 12:02 PM
RE: Clear Coat
I would normally get everything ready and wait for a reasonable day, however, seeing you are in Canada, I see your point about it being in April at the minimum. Seeing there will not be much good flying weather either... I would opt for spring when I can spray good paint outside and in the interim relax by drinking beer and vodka by the fire and try to keep the wife and kids amused for a few months!
Jim_Purcha 11-23-2009 11:37 PM
RE: Clear Coat
Actually Leonard in the paint shop at workoffered to spray the model for me. I work for a contract fabricator (welding, lasers, milling etc). I might take him up on this if I can get the decal work on the plane. I'm just concerned of him shooting too much clear coat.
Jim
dhal22 11-24-2009 06:35 AM
RE: Clear Coat
jim,
i would think you want a little extra clear coat. i do anyway as i'm going to spend some quality time sanding it smooth to a gloss finish. there are some airbrushing sites around that talk about how to do just that.
