Quadra-Aerrow Engines Get direct support for you Quadra-Aerrow Engines here!
Quadra 35cc Engine and 100LL Aviation Fuel
Old 11-14-2017, 08:33 PM
Red Baron Mike
My Feedback: (287)
Red Baron Mike's Avatar
Default Quadra 35cc Engine and 100LL Aviation Fuel
Any problem using Aviation 100LL fuel in Quadra engines? Does the higher octane pose a problem?
Old 11-15-2017, 06:49 AM
do335a
The real question is what benefit is there in using Av gas?
Answer- none.
It's not an aircraft engine and it's not operating in an aircraft environment. It's a chainsaw engine, an industrial engine which just happens to have an aircraft propeller stuck onto the output shaft if used in a model plane. No benefit to using Av gas in your chainsaw.
So why bother going to a more costly fuel for which it was not designed with no benefit? Unless you just happen to have some excess fresh Av gas lying around.
Old 11-15-2017, 08:21 PM
Kweasel
My Feedback: (29)
For me, 100LL doesn't stink and it stores very well. It does harden Tygon but wont touch black neoprene. Plus I get it for free! Avgas can be more difficult to get started when its very cold compared to fresh pump gas. Otherwise it runs fine and hasn't caused any problems beyond stiff fuel line.
Old 11-16-2017, 08:37 AM
Red Baron Mike
My Feedback: (287)
do335a:
Because I cannot stand the stench of pump gasoline, and it greatly affects my asthma. I asked if there was a problem using 100LL. I did not ask for a sales pitch on pump gasoline. Besides, the cost per flight is insignificant when compared to the overall investment made in large, "gasoline powered" airplanes!
Thanks for your response.
Old 03-17-2018, 10:49 AM
Red Baron Mike
My Feedback: (287)
As a follow-up on this thread, my newly acquired gasoline engines, both Quadra and Zenoah, all run great on 100LL aviation fuel and there is literally no smell. Even the exhaust has less of a smell than when using glow fuel.
I don't remember who suggested I try 100LL but thanks. I have now switched over to gasoline engines without any asthma issues.
Old 03-17-2018, 07:38 PM
nmav8r
I use 100LL in my DLE 20's with no problems .Our field is 4300 feet elevation . The exhaust is cleaner and doesn't stink and it gives my something to do with my sump drains
