Quadra-Aerrow Engines Get direct support for you Quadra-Aerrow Engines here!
Q-50cc oil/fuel ratio?
Old 12-04-2005, 06:06 AM
gadix
gadix's Avatar
Default Q-50cc oil/fuel ratio?
hi
can you please recommend oil type,(synti or not/partly) and what ration should i mix it?
what is the correct plug to use with the engine?
thx for the help
gadi, israel.
Old 11-21-2006, 05:54 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: Q-50cc oil/fuel ratio?
I've always run 32:1 with the usual synthetic 2 stroke oil available in most stores in the USA. These are either in the proper size to mix with 1 US Gallon or 2 US gallons. I don't know how it is set up in your country?
The plug I use and seen in other's US/Quadras is the Champion RCJ7Y (BANTAM HEIGHT)
