Quadra-Aerrow Engines Get direct support for you Quadra-Aerrow Engines here!
Quadra 42 Help!
Old 06-04-2006, 09:56 PM
spitmad
Default Quadra 42 Help!
Hi Guys
I picked up an old Byron P51 Mustang fiited with the Quadra 42 and belt reduction gear, can anyone help me with the following:
Is Quadra still around?
What fuel mix is best used?
Is there an electronic ignition system that can be retrofitted?
Will the Q50 fit the same gear reduction system (ie are the engine mounts, physical size etc the same as the Q42)
cheers
Alan
Old 06-12-2006, 09:42 AM
Iflyglow
My Feedback: (79)
Iflyglow's Avatar
Default RE: Quadra 42 Help!
I think Quadra has gone by the way side now. It is a shame, I really liked them. I think you will fid that the blades will flaten out with any more power than the Q42, and the performace will be worse. The blades were simply not designed for that much power. The drive system was originaly designed for a Q35.
Old 11-21-2006, 05:49 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Try this guy. He is the major distributor in the USA
http://bennettbuilt.com/page1.htm
