Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Manufacturers Direct Support Forum > Quadra-Aerrow Engines
Reload this Page >
Quadra Q52 had eat the screw of the Throttle Plate I Need replacement parts
Quadra-Aerrow Engines Get direct support for you Quadra-Aerrow Engines here!
Old 05-30-2007, 11:05 PM
Yastreb
Default Quadra Q52 had eat the screw of the Throttle Plate I Need replacement parts
So better I will post my e-mail correspondence with quadraaerrow.
Maybe you can help me to find piston and ring?
--- Forwarded message --
To: <[email protected]>
Date: 24.05.07 11:33
Subject: Fw: Re: request on spare parts for Quadra Q52M
Hello Klaus!
i am reapiting my request maybe you did not recived it.
Regards
Oleg
Date: 14.05.07 15:05
Subject: Re: request on spare parts for Quadra Q52M
Hello Klaus!
I was really happy to see the e-mail from you.
Yes was lost the screw of the Throttle Plate.
It was never removed.
And like I understand you don’t have Clutch.
We can proceed next ways:
If you accept credit card then this way if not so maybe web money or
Western Union.
End you can send my by mail (DHL or FedEx)
I need:
Piston 1 piece
Piston ring 2 pieces (second ring for secure if first can be broken on
installation or over mishaps)
Gasket of cylinder 1 piece
And if possible Clutch 1piece (it make a grate job to help my start the
engine)
Thank you very much.
Oleg.
> Hi Leskin,
> Sorry to hear about your Mishap.
> As I understand it you lost the screw out of the Throttle Plate ?
> Was this ever removed ? since at least on later Carbs that Screw is
staked
> to prevent this!
> I have aPiiston from our R&D Stock & a P.Ring for you.
> The Clutch Brg. can be obtained from TS Engines, WI.
> Pls. advise on HOW you want to proceed.
> Best Regards,
> Klaus Nowak
> T&F 905-440-4435
> ----- Original Message -----
> From: "leskin oleg" <[email protected]>
> Cc: <[email protected]>
> Sent: Wednesday, May 02, 2007 2:48 AM
> Subject: request on spare parts for Quadra Q52M
>> Hello Klaus!
>> I have (and right now had) new Quadra Q52M engine. It was my firs gas
>> engine I purchase it in Mexico in 1995 year.
>> I break in and left for a time. Last week end I put it to my airplane
>> start it. It was running very well with prop 22x6 had trust about 13 kg
>> (even my friend was scared), but good things not always during long
time.
>> I so a fire from cylinder and some metal pieces fly away from exhaust. I
>> immediately shut off the engine, but it was late, it had internal
damage.
>> Disassemble of the engine had discover that piston lost one little piece
>> in lower part and top of cylinder have rumpled surface. The cylinder is
>> clear only at top of cam have rumpled surface. The problem was in
>> tie-bolt that holding engine throttle it was suck in cylinder.
>> So I very sad, that so many time waiting of flaying in this engine, and
>> it is broken.
>> Maybe you can supply me piston, piston ring and if possible overrunning
>> clutch for spring starter.
>> Thanks you very much.
>> Leskin Oleg
>> [email protected]
--- End of forwarded message --
Regards
Oleg.
ID:	694711   Click image for larger version
ID:	694712   Click image for larger version
ID:	694713   Click image for larger version
Old 05-31-2007, 10:27 AM
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: Quadra Q52 had eat the screw of the Throttle Plate I Need replacement parts
The guy responsible for Quadra 52's is . . . . There's a new jug out for the 52 with larger better flowing ports.
Tom Sabatino
414 425 5894
[email protected]
