Quadra-Aerrow Engines Get direct support for you Quadra-Aerrow Engines here!
Q80 Prop Bolt Size
Old 06-28-2009, 05:23 AM
smeegarn
Default Q80 Prop Bolt Size
Hi all
I have a new Q80 (old but not run until this year) which is a great motor in a seafury but today the spinner let go and subsequenty prop bolt, prop and everything else that makes it go, and it turned into a 43lb glider. All ended well but I cant seem to find the bolt size for the prop bolt. If anybody can help it would be appreciated,
thanks
Peter
Old 06-28-2009, 04:37 PM
51er
Default RE: Q80 Prop Bolt Size
Hi Peter,
I fly with Q 75 and Q100, both use 5/16-24 x 1-3/4. (hex cap screws)
Tru-Turn # TT-0524-A.
Give them a try, should solve your problem.
G
