Q75 needle settings?
What are the factory settings for the carb on a Quadra75? Also, what is the max rpm? Thanks.
Vince |
RE: Q75 needle settings?
One more question- are there different length prop hubs available? This one is about 2.5 inches long. If there is one available that is shorter, I could get a perfect fit within the cowl. Thanks.
1 Attachment(s)
High 1 1/4
Low 1 1/2 This is to start out, then you have to fine tune it, with turning them in. Prop special and shorter is available with special request as a non standard. Thanks, Hanspeter Naef U.S. Quadra Aero Engines www.usqengines.com |
