Reload this Page >
hopping up OS 1.60
hopping up OS 1.60
Old 09-16-2010, 06:05 PM
magiccrazy
My Feedback: (65)
Default hopping up OS 1.60
HI guys just wondering if anyone has any tips on hopping up a OS 1.60 I need a little more power without changing the engine.
thanks
Old 09-16-2010, 09:18 PM
big max 1935
My Feedback: (9)
Default RE: hopping up OS 1.60
Use more nitro in your fuel. Max H.
Old 09-17-2010, 01:26 PM
jaka
Hi!
Use a pipe!
Old 09-18-2010, 08:59 AM
sedrick
Try different props. The APC 18X6 W seems to work the best for my 160's but the high end compsite or graphite props may be even better
Old 09-18-2010, 12:00 PM
Gray Beard
My Feedback: (-1)
ORIGINAL: sedrick
Prop selection. Start testing and see if you can find a prop that works better for you. More nitro will give you a few hundred more RPM but remove more money from your pockets. A pipe works great but they tend to only work well on the high end of the RPM range and tend to loose reaction in the mid range of operation. About the only thing we as owners can do to these engines is raise the compression and that can make things worse. Someone like Clarence Lee may be able to change the port timing and get more out of them but it's beyond most of us. Props make a huge difference. For more thrust you can try a longer prop with a smaller pitch and a smaller prop with a bigger pitch for more speed. There is no one magic size of prop, you must test to find the one that works for you.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
