What Paint matches ultracote??
IA
Hello,
Well I have a fiberglass cowl for my GP extra 300, and I covered in ultracote. I don't want to paint the cowl just a solid color, I want to add striping that matches the fuselage, soI want to know the best way to do that. Ultracote on fiberglass?Matching paint? Tips and advice greatly appreciated!!
Jason
Jason
My Feedback: (13)
RE: What Paint matches ultracote??
I have ironed on Ultracote on top of fiberglass, but only on areas where the fiberglass part is nearly flat. And if the ultracote piece is fairly small like a stripe. If you want to paint, the high-end way to go is to buy pre-mixed automotive paint from Tony Stillman at Radio South (http://www.radiosouthrc.com/). You tell him what color you have and he already has the recipe to match that color (or if he has never supplied that color you can send him a sample and he will create the right color to match).
The only downside is the cost. I think it's like $40 minimum for one color. And you need a sprayer / compressor.
My Feedback: (-1)
Ultracote used to make there own matching paint but they no longer do. My LHS still has some of the colors on the shelf and I try to buy a can every time I go there, I use quite a bit of there red. Getting really hard to locate. I have had it color matched at the Dupont paint store too with good luck. I have also found matches at the local hardware store.
