Solo prop questions
FL
Solo prop questions
Can the blades by infinitely adjusted? Solo props told me through e-mail they can without the "actuating mechanism inside". My goal is to turn the blades enough so that I can make a pusher prop. If anybody has a Solo prop will you study it and determine if I can or not? Thanks a lot!
Caylen17
Caylen17
FL
RE: Solo prop questions
ORIGINAL: HighPlains
No you can not make a pusher prop by just turning the blades. However, they do make a reverse pitch prop if I read their web site correctly.
Where did you find that?
ORIGINAL: caylen17
Looking from the back of your boat, a rear-facing engine will spin the propeller counterclocwise and will push the air away from itself, instead of towards itself like in puller crafts.
Check this thread for some pictures:
http://www.rcuniverse.com/forum/m_76...tm.htm#7682412
Ask them is the pusher props they offer are suitable for internal combustion engines, since no many twins have counter-rotating engines.
If the mechanism would allow you to rotate each blade 180 degrees over itself, the airfoil would be backwards; hence, you would get some pushing force, but not enough.
