Reload this Page >
To anneal or not to anneal, that is the question
Old 12-29-2010, 10:25 AM
jollycub
Default To anneal or not to anneal, that is the question
I decided to make my own control rods, and have a 2-56 and a 4-40 die with handle. I also purchased welding rod at 1/8" and 3/32" at 70,000 tinsel strength.
I cut threads on the 1/8" welding rod and it fit my yokes perfectly. Then I tried making a "Z" bend on the other end. I have a tool that makes pretty good z-bends, but the tool doesn't have enough strength to make a good z-bend with 90 degree angles. If I heated the rod up, then let it cool, would the z-bend tool have an easier time making good bends? Would I destroy the integrity of the rod? Should I look at other metals for the rod?
Carroll
Old 12-29-2010, 10:28 AM
jeffie8696
jeffie8696's Avatar
Default RE: To anneal or not to anneal, that is the question
Must be Christmas rods.
Old 12-29-2010, 12:06 PM
welder101
If you heat the welding rod up then use your pliers while it is hot. Should be able to bend it then.
Old 12-29-2010, 12:53 PM
Johnnysplits
ORIGINAL: jeffie8696
Now thats funny!!! LOL
Old 12-29-2010, 01:27 PM
jeffie8696
jeffie8696's Avatar
Tinsel, couldnt resist.
Old 12-29-2010, 05:27 PM
Lnewqban
Lnewqban's Avatar
Carroll,
There are many types of welding rods, but the majority is made of low carbon or structural steel.
That type of steel cannot be hardened or made brittle by the use of heat.
Heat will help you soften the metal only while bending (not after the metal cools down), but it may damage any plastic part of your tool.
There are few things that a good hammer and vise cannot do with bending cold metal, as long as you provide a small radius on the internal surface as to prevent cracks.
Old 12-29-2010, 05:41 PM
Missileman
Missileman's Avatar
Have you considered just threading both ends and using 2 clevis' ?
Old 12-29-2010, 06:31 PM
ameyam
To anneal the rod you need to heat it to about 900 Deg C and then cool it slowly. So I am not sure the heating you will do wil be able to 'anneal' anything.
Simply heat till it becomes a bit softer and bend if your tool doesnt have any plastic parts. Otherwise simply thread both ends and use clevises
Ameyam
Old 12-29-2010, 08:01 PM
jester_s1
Moderator
Actually, to anneal simple carbon steel you have to get it to its critical temperature, which is around 1550 degrees if there aren't any alloys present. Music wire is just about always 1095 steel, which is basically just iron and 1% carbon. It anneals easily by heating to critical temp (glowing red hot in typical indoor lighting) and allowed to cool on its own to room temperature. That won't get it dead soft, but it will make it easier to work than the way it comes from the hobby shop, which is hardened and then spring tempered.
Old 12-30-2010, 07:32 AM
landeck
ORIGINAL: Missileman
It is never a good idea to use threaded clevis on both ends of a push rod.[:-] The rod can twist and work itself out of the clevises.
Bruce
Old 12-30-2010, 11:49 AM
sscherin
sscherin's Avatar
I usually thread one and end and solder a celvis on the other..
Old 12-30-2010, 08:35 PM
invertmast
My Feedback: (23)
invertmast's Avatar
ORIGINAL: landeck
Bruce
thats why you put a machine nut with loctite to lock the clevis' in place to keep them from twisting. Or you can use nylon clevis' and not worry about it.
Old 12-31-2010, 07:57 AM
landeck
ORIGINAL: sscherin
invertmast, sscherin's way is the way I have been doing it for the last 37 years. Never a failure that way. I have over that period seen a few failures where people have tried to use two threaded clevises on a control rod.
Bruce
