Quick CG Question
NC
Quick CG Question
I just picked up a twist 40 at a swap meet. I went over the whole thing and fixed the little problems I saw. Well i went to check the CG and it is way tail heavy. Am I supposed to check the Cg with a full or empty fuel tank? I am hopeing to get it out this weekend for my maiden on it
TX
RE: Quick CG Question
Do it with the fuel tank empty and the airplane upside down. CG should be 4 to 5 inches behind the leading edge near the fuselage per the assembly manual.
NC
Thank you for the answers. I thought it was empty but just wanted to make sure. I will have to try the battery under the fuel tank because the CG is way off. I may still have to add some weight to the nose. This is the first plane I have had where the weight is off this much and just wanted to make sure I do it right.
