Dual drive servos
My Feedback: (7)
Dual drive servos
Need help on this one. Anyone know of a sail wench servo that has dual out put shaft, in other words the drive shaft extends through both top and bottom. Or a gear box drive for the same servo that will allow for an extended shaft. Any help is appreciated.
johnnyO
johnnyO
RE: Dual drive servos
don't know of such a servo, but i would think another drum could be added to the existing one. a decent machine shop should be able to turn a double drum that would mont on the shaft., or buy a replacement drum and mount or epoxy it to the exhisting drum.
are you looking to sheet jib and main together, or two masts?. if jib and main, it can be done with one line on a single drum, for that matter two mains, (or main and mizzen) can be done also.
