Hitec HS645MG ?????
NC
Hitec HS645MG ?????
Putting together a Great Planes Super Stearmen and bought Hitec HS645MG servos, I have used Hitec in the past without issue but these Groan all the time like they are under a strain and their not, is this common? I am using a 2000ma 6v 5c battery fully charged.
Thanks for the Help!!
IL
RE: Hitec HS645MG ?????
Mine like to. I think if the linkage puts even the slightest twist on the servo arm it will groan a bit. I wouldn't worry about it too much.
IL
Do they stop if you bump the control surface a bit? If so, it has been my experience that these servos are a bit noisy around center. I'm sure they are fine.
