Plane storage
RI
RE: Plane storage
some of my control line models were hung by the props and never had a problem over the years. I oiled them up with 10w motor oil before extended inactivity.
CO
RE: Plane storage
So along those same lines, I have a GP Super Sportster 40 with an old OS Max 35 or 40 I think it is. I can't see any markings or indication what size it is. Anyway, it's about 20 yrs old - it's been sitting in my parent's garage all this time. The motor was never prepared for that kind of neglect meaning I didn't oil it - and it appears frozen.
SO.... do I have any chance of bringing it back to life would you guys say? Or should I just plan on a new engine?
Thanks in advance.
Thanks in advance.
AZ
RE: Plane storage
I would take the glow plug out and see if it turns over. Maybe add a few drop of nitro or afterrun oil and see if it turns without the glow plug. (Turning by hand). Most likely you may have to dissassemble the motor and either clean or repair parts, or if you want to skip the fun, you can just buy a new one.
RE: Plane storage
Soak it for a couple of days in glow fuel, it will free it, then pull the backplate and check for rust, if there is a lot it needs new bearings. If you want a new engine any 40-46 sized is fine.
http://www3.towerhobbies.com/cgi-bin/wti0093p?&C=GCD A lot of people will suggest an O.S. they are great engines and user friendly. I prefer either of the tigers Super or PRO Thunder. Both are more affordable and excellent engines.
My Feedback: (-1)
RE: Plane storage
ORIGINAL: jstrach
If I want to go down the path of getting something new/modern as a replacement motor for the Sportster 40, any recommendations on an engine?
CO
RE: Plane storage
Good information, thank you.
What about the Evolution engines that are appearing on RCU pop-up ads?
http://evolutionengines.com/Products...rodID=EVOE0461
Do we know anything about their performance?
RE: Plane storage
Some people love them, some people absolutely hate them. I have the one that came with the H9 P-51 pts. I have taken all of the trainer junk off, flywheel, and needle stops. It was a real dog and did not run worth a crap with it on.
That being said it is a good reliable engine now. Not a powerhouse but solid.
My Feedback: (-1)
RE: Plane storage
I'm not a big fan of them but I have seen here a lot of people like them. There is a thread floating around here as a poll asking for you to post your favorite engine. Either here or in kit building or beginners forum. Go look around for it and see what other choices are.
RE: Plane storage
Heres something I learned, try putting a couple drops of lighter fluid in the carb. and the give it a couple hand turns. that usually does the trick!
My Feedback: (-1)
RE: Plane storage
Only if it still turns over. Products like Marvel Mystery Oil will loosen things up too if the engine rolls. A couple of drops of lighter fluid is a trick all my east coast and mid west frineds do to get there engines started when it's freezing outside. It's good stuff!!!
