Control rod hookup to the servo arm, what's you preferred method?
Control rod hookup to the servo arm, how do you like to do yours? I know there are many ways to do it, I just want to see some different options on how some are doing it.. If you have links or pictures, feel free to post them... I am getting ready to do them tonight and I am up in the air on which method I want to use...
Jimbo
Jimbo
RE: Control rod hookup to the servo arm, what's you preferred method?
A simple 90 degree bend and http://www3.towerhobbies.com/cgi-bin...?&I=LXAZC3&P=0 works well
I always used Z bends on my hookups on my elevator. & rudder. and usually soldered threaded couplers on my ailerons and went with a quick connect...
I have a elevator connection to make on my little Toni that has two pushrods for the elv. to one servo. It has you bending the one pushrod and clamping it to the other, then make one hookup to the servo.. I plan on wrapping the pushrod and soldering it and was thinking of soldering on a threaded coupler and using the Dur-bro heavy duty ball link.http://www3.towerhobbies.com/cgi-bin...?&I=LXFPW7&P=0
Anyone see a problem doing it this way?
My Feedback: (158)
ORIGINAL: Mustangman40
Jimbo
Jimbo
My Feedback: (158)
I have a elevator connection to make on my little Toni that has two pushrods for the elv. to one servo. It has you bending the one pushrod and clamping it to the other, then make one hookup to the servo.. I plan on wrapping the pushrod and soldering it and was thinking of soldering on a threaded coupler and using the Dur-bro heavy duty ball link. http://www3.towerhobbies.com/cgi-bin...?&I=LXFPW7&P=0
ORIGINAL: scale only 4 me
Are we talking a 15oz foamie or a giant scale or something in between?? without knowing what control surface on what type of plane it's really had to accurately make a recommendation
Jimbo
Jimbo
Sounds like a good plan to me
I have these servo arms and was going to go with them on Hitech 645MG http://www3.towerhobbies.com/cgi-bin...?&I=LXD670&P=0
with those ball links. Do you see any problems with the arms, or should I upgrade to metal? It's a 60 size plane with a 90 on it, not real fast at all, but I want stout hardware on it...
ORIGINAL: AllTheGoodNamesAreTaken
Z or 90 deg bends aren't going to enlarge a servo arm any more than a metal clevis would.
I like ball links on all servo / control surfaces where possible on 60 size and up.
thanks for the pic..I noticed that some of your ball link nuts are on top, is there a reason for that?
ORIGINAL: airbusdrvr
Just don't use easy connectors on anything you can't afford not to lose!
What about using them on throttle, or front nose wheel,is it common for themto fail?
My Feedback: (158)
SO4M,
SO4M,
good luck
My Feedback: (180)
Jeff,
thanks for the pic.. I noticed that some of your ball link nuts are on top, is there a reason for that?
Yes - ease of adjustment. I put the bolt through the control horn from the bottom, add a nut and tighten with Loctite (purple). There's no need for the brass ball in this application.
This way I can mechanically center everything by adjusting threaded sections of the pushrod. Once everything is centered I Loctite the top nut in place.
IL
I use mostly Z bends, and easy connectors. All my aircraft are .90 or smaller. Obviously on some pull-pull set ups I use soldered clevises.
I think EZ connectors get a bad rap. I've never had one fail, but I set them up right. I use thread locker, tighten, then let the threadlocker cure.
90 bends on small glow stuff with ez links(http://www3.towerhobbies.com/cgi-bin...?&I=LXAZC3&P=7), sometimes i use ez connectors too (http://www3.towerhobbies.com/cgi-bin...&I=LXE114&P=ML) ball links on 3d stuff 1.20 on up and all the way on my gassers
My Feedback: (-1)
ORIGINAL: ArcticCatRider
My Feedback: (158)
ORIGINAL: Gray Beard
I'm not sure what it is you solder on a pull pull. Next time you set up a pull/pull give rigging couplers a try. Makes your job a lot easier.
I've several times when space or access is tight connect the clevis directly to the cable, then use a servo wheel and have the coupler and a piece of Nyrod mid-span along the cable to adjust tension.
Here is an example, the push rod is for the Rudder, the pull cables are for the retractable tail steering on my Ziroli P-47
I have it the same way on my Kingfisher where the rudder connection is buried with in the fuse and have no access.
p.s.
Before you get any ideas,, the 5645 operates the Robart retractable tail wheel mechanism , not the elevator I have it programed to run a 1/10 speed. Z-bends do come in handy sometimes
Scale,
I did my elv.&rud. last night and it came out good. I'm not sure if this is good practice or not, butI tapped the4-40 bolt to the servo arm, then put the nut on the bottom with some thread locker. Is there any reason why tapping the servo arm would be a bad thing, it seems to me like a real solid way to connect..
My Feedback: (9)
For me, it's hard to beat a ball link and soldered on clevis. This is over kill in a lot of situations. For the last 4 years I have been flying mostly 3D. If you have a plane where 20% of the wing is aileron. Every little bit of play is magnified with a 5" deep control surface. In this situation a Z bend is just not going to cut it.
david
david
