Sullivan Dynatron switch from 12v to 24v and back
My Feedback: (17)
FL
Hello Fellow RC'ers.
I have a Sullivan Dynatron that I am going to be setting it up with a A123 6s1p thats 19.8v at2300mAh.
I would like to put some kind of relay switch tobe able to switch back and forth from19.8v to 12v and then 19.8v as needed.
Anyone have any kind of ideas or schematics.
Fatuba
My Feedback: (13)
RE: Sullivan Dynatron switch from 12v to 24v and back
Something like this will be close. With the switch in oine position you will be running from one battery (9.9 volts). Put the switch in the other position and you will have the full 19.8 Volts.
My Feedback: (17)
FL
The a123 is one battery 6s1p producing 19.8v
ORIGINAL: DMcQuinn
My Feedback: (66)
yes dont worry about the extra rpm on smaller engines. if you flooded the engine it will breaksomething on 9 volts or 19 doesnt matter.
K.I.S.S = Keep It Simple Stupid
Not calling you stupid either lol just why add complexity to something so simple.
My Feedback: (-1)
ORIGINAL: Fatuba
R u saying that 19.8v in small burst (no more than 10-15 sec) on a 26cc gas engine won't harm the engine?
My Feedback: (17)
FL
I usualy start my gas engines by hand also but this 26cc is breaking in andsometimes it does not want to start by hand.
I will first flip it a couple of times like I usually do and then if it does not start hit it with the Dynatron starter at 19.8v.
Thanks for all your input guys. Makes life easier.
CA
Why does it matter why he wants to do it?
It's what he wants to do so help him out if you can.
KW_Counter
KW_Counter
My Feedback: (-1)
ORIGINAL: KW_Counter
KW_Counter
KW_Counter
