Reload this Page >
rudder/nose gear
rudder/nose gear
Old 06-08-2011, 11:31 AM
rachelandellie
Default rudder/nose gear
hi guys my gear and rudder move in opisite directions and all my servo wires and plugs seem to be plugged in correct,,, when i input left rudder,,the nose wheel turns right so i checked all my connections and they seem to be the right bloody way!!! is there a servo reversing extension or module i can buy to plug inbetween to get this nose wheel turning with my rudder , also checked mixes and so on onthe radio nothing seems to be set to do this, its the starmax fa18 90mm everything else is satisfactory ;
Old 06-08-2011, 11:58 AM
David Bathe
David Bathe's Avatar
Default RE: rudder/nose gear
Move the quick link to the other side of the servo horn.
Old 06-08-2011, 03:09 PM
Villa
Villa's Avatar
Here are two solutions that come to mind. 1- Move the front wheel arm to the other side. 2- If the servo arm has the front wheel push rod and the rudder push rod on the same side, move the front wheel push rod to the other side. You will have to change the servo arm from a one side arm to a two side arm. If one rod is currently on one side and the other rod is on the other side of the servo arm, put both rods on one side of the arm.
Old 06-08-2011, 04:41 PM
Lnewqban
Lnewqban's Avatar
See the schematic for a layout that works.
