Nylon tube too big for threaded rod
I'm building my 4 Star 40 and I ran into a weird situation. I'm at the part where I'm working with the servo/control linkages. The instructions say to cut two 2-56 steel rods and then thread the threaded end intothe inner (smaller) nylon tubes that runthe length of the fuse inside the outer (larger) nylon tube backto the exit points. Theinner tube fits fine intothe outer tube and slides easily back and forth but the threads of the rods slide easily into the smaller tube. So, there is no way to thread the rods intothe tube because the inside diameteris toolarge and the threads won't grip.
Any suggestionsas to how I can work around this? I'm afraid to glue the rods into the tubes in case Ineed to make adjustments later but Idon't see any other way.
RE: Nylon tube too big for threaded rod
I ran wooden dowel pushrods in lieu of the nyrod setup. Got any spare dowel rods? A local hardware store should have them if you don't and they're cheap!
I would first check to see that your 2-56 rod really is 2-56. Second option, buy a good set of these, http://www3.towerhobbies.com/cgi-bin...&I=LXFU90&P=ML
I called Sig but their techs don't work on Fridays so was told to call back on Monday. I wish I could take every Friday off.
If I ordered from Tower this morning I'd have my parts by Tuesday or Wednesday,so will just go that route. Too bad I already ran and glued in the larger nylon tubes; the Sullivan golden-rods look good. They are cheap enough that I may just order them anyways along with some 4-40 rods. Of course now by servo arm connectors probably won't work with 4-40 rods.
I hate issues like this but on the bright side, this is usually when I learn about new techniques and products.
You could try some bicycle wheel's spokes.
They may have the extra thread external diameter that you need.
Another option is to stretch the ends of the inner plastic rod with a flame.
By doing that, the interior diameter will be reduced as much as you need.
Best luck
Best luck
I put a lighter flame to the tube and once it started to soften I put the tube under cold water. I then was able to thread the rod into the melted tube. Hopefully I can do the tail-feather end without burning my airframe to bits.
ORIGINAL: Aiden88
I fully agree that heating and stretching the tube is way too risky. You do not know how you may be changing the chemistry. I would look for a safer alternative.
When I assembled my 4*60 ARF, several people said I should replace the nylon pushrods because they expand and contract with temperature changes. I found 4-40 solid wires fit very well in the stock outer sleeves so that's what I used for elevator and rudder.
ORIGINAL: carrellh
I gave them a pretty intense stress test trying to pull the rods out but couldn't get them to budge. I had to use pliers and a vice grips to even get the rod to thread inside the tube. When I water cooled the tube it hardened like a rock. With that said, I'm not going to risk losing my model because I was too lazy to take a trip to the LHS for a $2.00 fix. I'm not one to ignore good advice either, Looking like Tuesday will be a hobby shop run to find a more reliable solution. Thanks guys.
My Feedback: (7)
Are you sure your rods are 2-56 and not 2mm? Did they come with the kit or did you have them on hand? I have never encountered 2-56 rod that would not tightly thread into nyrod inner tubes. You may have a non nyrod product, but it would seem a good idea to verify dimentions of what you have. Good luck.
The 4 Star kit comes with six 10" 2-56 rods. They are the ones I'm using and they thread into clevis' that come with the kit just fine. All of the hardware is from the kit. However, when those rods didn't work I tried using other rods off my other .40 size models but the threads just slide in and out of the tubes. It is really weird but appears that the outer diameter of the tube is right but the inner diameter is too large.
The 4 Star Kit is pretty basic and their isn't a lot of hardware. I've triple checked everything and pretty much have concluded that I've just got unlucky with these tubes. Fortunately it's an easy fix.
Between the #2-56 and the #4-40 US threads, there is the #3-48, which takes a #47 drill bit before tapping.
Drill bit for 2-56 is #50 and for 4-40 it is a #43.
Since you will not use the heated and stretched tube-rod, it would be good to do some destructive test on it.
I found out from a guy in a 4 star thread where a hegot his kit and then a day later got a package of nylon tubes from Sig explaining they had a batch of 4 Star kits with the wrong tubes. Feeling a bit vindicated...
I finally got around to calling Sig back and he confirmed the batch of bad tubes... Replacement tubes are on the way.
