need help to program radio JR8103
RE: need help to program radio JR8103
First you have to select differential(Flaperon)in the wing type, then seclect the switch and then set the flap amount, been a while since I have done this on a 3810 as I replaced it with a DSX9.
Cheers
Cheers
Yep, rest of world calls it a 3810, US specific is branded 8103...Same as the ST G2320, you guys are the only ones that know it as a G2300...must be something in the air over there...can't spell 'colour' either...
Evan, WB #12.
Evan, WB #12.
ORIGINAL: handyman
its a 8103 radio is that the same?
Cheers
