Lager size biplane
WI
Lager size biplane
Iv gotten a 63-65 inch biplane and i am trying to figger out what i should put on it for a power system i dont know if a 26cc gasoline engine is to large (but i am guessing it is) or maybe stick with 2/4 stroke engine or spend bit of money and get an electric system. any thoughts on the subject would be nice will post some pictures of this plane i have no clue who built the model but it was a kit and it has no marking to say who the manufacturer is.
thanks,
tesla
thanks,
tesla
RE: Lager size biplane
It's not so much wing span as it is weight....The Areoworks Pitts Python is a 70 inch span and a 50cc works well...I'm gussing that it weighs in at 17 lbs.......If you can but a 50 on yours....both under the cowl and prop clearence...then get a 50cc.....remember that throttle is not an on/off switch......good luck
WI
there i hope these help. i have no clue what model this is so if ya know it would help. it weights about 8 lbs with nothing in it (no tank servos wheels linkages etc). 64 inch wing spand (top wing)
tesla
ps any more info you need i can get hopfully.
My Feedback: (-1)
I can't tell from the photos but it looks like a Waco that doesn't have a cowl??? Anyway, it was set up with a glow engine at some point. At that weight a good .91 or 1.20 four stroke or something like a DLE 20 or 30 cc gas engine. A 30 may be a bit much for it though??
WI
so if i picked up a 20 cc im guessing that would still be a bit much for the waco. might just have to stick with a nitro engine haha.
tesla
tesla
My Feedback: (-1)
A 1.20 four stroke is a 20cc. With the short coupled nose section you may need the extra weight to get a CG without adding lead. Any full scale Bipe that used a rotary engine then got modeled for RC use is going to require added nose weight, sometimes a lot. Because you don't have an engine on hand you can install all your gear into the plane then set it up to get the CG and see in advance how much weight you will need, then pick an engine that would help you achieve that goal. I attached a photo of one of mine. The plane is scratch built, 68 inch span and it came out at just over 12 pounds with a 1.20 four stroke. It ended up requiring about 3 pounds of lead in the nose to CG and was never a good flying plane. At almost 16 pounds the 1.20 flew the plane but not very well. I have used gas engines in it to lighten it up and it was better but not great. I gave the plans to a friend and told him about the weight problems so he went with a 40cc CRRC gas engine. The lighter plane with the heavy engine is a much better plane all around. You may need some weight in the nose so a bigger engine may be the best way to get it. It's up to you to figure out what is needed. A .60 may fly it but it could require a ton of lead up front? Better to use a bigger engine instead of lead. Dead weight is just that.
My Feedback: (-1)
ORIGINAL: smithcreek
Isn't that a Sterling Stearman? Other than the angle of the N struts it looks like one. They fly on a .60, better with a .90, great with a 1.20 fs.
My Feedback: (14)
IN
I thought Stearman also. And this plane doesn't look that large too me. The motor mount looks small as well and doesn't really look like there is room for a gasser. Remeber you need room for the ignition module and battery up there some where.
My advise, take it to your local club so some one can see it up close and then they will be able to make a better determination of power needs.
steve p
steve p
WI
the local hobby shop sucks. it is compeatly horrible. i can garrentee that it is 64 inches just measured it. the motor mount if for a nitro engine so it is going to be small. Might just have to stick wiht geting a .60 cheap and see if that is enough
tesla
tesla
My Feedback: (-1)
Motor mounts can be removed and bigger ones installed. Other then one problem that was repaired really fast I have been having good luch with the SK .91 two strokeengines too. Low RPM and high torque.
Now I'm going to ask the big question: How much RC flying have you done?? Doesn't sound like you understand much about the airplanes or there set up and this Bipe is NOT a learning tool!!
WI
Well haha i have been flying for 6 years now i love 3d but when it comes anything other than 2 strokers i become lost. So that is why i come on here to see if i can get help. I may be new compared to some of you guys but i help train new bes at our local club how to fly and has gotten couple of my friends into the hobby. (only 16 just an fyi haha)
tesla
tesla
It is indeed a Stearman, and at 65" not a big model. Scale flying, something like the .60 two stroke it was originally designed around, a .90 FS would be perfect. If you have the experience, and don't mind cutting up the cowl, then a .90 TS or 1.20 FS will give exuberant flying.
Evan, WB #12.
Evan, WB #12.
My Feedback: (-1)
ORIGINAL: pimmnz
It is indeed a Stearman, and at 65'' not a big model. Scale flying, something like the .60 two stroke it was originally designed around, a .90 FS would be perfect. If you have the experience, and don't mind cutting up the cowl, then a .90 TS or 1.20 FS will give exuberant flying.
Evan, WB #12.
Evan, WB #12.
