Balsarite vs StickIt
My Feedback: (-1)
RE: Balsarite vs StickIt
Neither. If the wood is dust free I haven't ever had a problem getting any type of covering to stick well. If for any reason I think I would like the covering to hold better in any area I have a big can of lacquer hair spray I can give the wood a light misting with. Someone here mentioned the hair spray once so I gave it a try and it works great.
My Feedback: (-1)
ORIGINAL: TomCrump
I'm with Gray Beard. I used to use Balsarite, but switched to hair spray.
CA
I have trouble keeping it on the cheeks of the engine compartments, WM Mach I & II.
Especially with recovering because there is usually a bit of fuel in the wood.
Which type of hairspray is preferred?
KW_Counter
KW_Counter
My Feedback: (26)
I've used both, and prefer Balsarite. Stixit is thicker and while it works, it is easy to get a buildup of it which shows as a little lumpy under the covering. This is not as noticable under 21st Century fabric as it is under high gloss Monokote. I still use Balsarite on hardwood or plywood which does not hold the covering as well as balsa. It is also ideal on "cheeks" like mentioned to hold the covering fast at edges exposed to fuel and exhaust.
Banned
I use 4 coats of Balsarite Conditioner when I want to stiffen thin balsa and or fuel proof area's that might be exposed to glow fuel. But for tacking down Solartex, Mono,Ultra or China-Kote, I just use a white clean towl and rub down the area that's going to be covered until I don't see any more residue on the towl. Then I know the balsa is clean enough to cover. So far I haven't had a main problem of the covering wanting to come off.
There were times I do hit the edges once or twice a year to make sure she stays down out of precaution. I did once last week have Solartex insignia's on Solartex covering start to come loose after a flight, but that was my fault for not checking it before I flew that day. It was a easy fix, when I got home I just hit it quickly with the trim iron.
Pete
Pete
I'm a dope fan so use Koverall which has no adhesive. To attach Koverall to structure I use Stix-It but Balsa Rite works, too. The Koverall has no glue so is lighter than the other 'tex' type coverings.
