LiFe Batteries
Old 07-24-2011, 12:29 PM
jetmech05
Default LiFe Batteries
I have been running Li Ion batteries with regulators in a couple of ships...I re charge when voltage fell below 7V with a 1 amp load.
Picked up a couple of Life batteries A123's right off the charger they fall below 7V with a 1 amp load.... what is the best voltage to re-charge at?
Thanx in advance
Old 07-24-2011, 12:49 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Default RE: LiFe Batteries
A123s are a different animal completely, don't go by the voltage alone, the nominal Voltage is 6.6 or 3.3 per cell. and they will hold at 6.7-6.8 for the whole charge, then fall off fast.
What you need to do with them is charge, fly a complete flight or 2, and then recharge, then calculate how many Milliamps you had to put back into the pack for X amount of flight time,, then you can figure your flight time per charge cycle.
Good luck,, I love mine
Old 07-24-2011, 10:45 PM
TimBle
For LiFe battery packs with a nominal of 6.6V recharge at 6.5V.
For Life battery packs with a nominal of 6.4V, recharge at 6.4V.
Below these voltages you are running a huge risk as you are approaching the "cliff" (they drop off super fast.)
I am not a fan of the fly, recharge and fly methos as you may not be pulling the same amperage on every flight. Depends on manoevres, airspeed, air density. E.g I tried the fly and charge over several flights. I found that on my pattern plane flying the same schedule over a 6min flight I was using from 80m.A to 130m.A.
Sure it provideds you with a good idea of how many flights to expect before recharging but the commercially available battery checkers for Life and LiPo are accurate enough to provide the same information with a larger safety margin.
And Safety is the main reason why we check, right?
Old 07-25-2011, 03:41 AM
scale only 4 me
My Feedback: (158)
Timble,
I agree it's not a perfect system, but it gives you a good idea how much flight time a charge will give you.
Last week a buddy was showing me his FMA Cellpro 4s charger, it calculates and shows you the pack capacity % before the charge cycle begins,, can be used as a battery checker and a charger,, for $55-$60 I may pick one up.
p.s.
I wouldn't fly any type pack when the shown voltage is under the nominal rated voltage,,, IMO that's just crazy
Old 07-25-2011, 05:45 AM
jester_s1
Moderator
No need to buy a charger just for this unless you just need another charger. I use them and just erred on the side of recharging too soon for about 2 dozen flights until I had a good average figure for battery usage. Now I recharge at roughly the halfway point and have zero problems.
