Reload this Page >
need a 10 c expert
need a 10 c expert
Old 08-06-2011, 09:34 AM
frank99
My Feedback: (29)
Default need a 10 c expert
trying to set up flaps on a fun cub and use a switch for 3 settings up mid and down read futaba manuel and still lost thanks to all that can help frank
Old 08-06-2011, 12:59 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Default RE: need a 10 c expert
Frank,
There is a pretty easy way to do it
go into the Basic Menu-
>AUX-CH
>CH6 (or what ever channel you flaps are on)
>assign SwC (switch "C",, that is the only 3 position switch)
Then go to the End Point menu
Center switch position will be your "mid flap" position,, you can fine tune that with the sub trim, (just keep in mind that will move the other end points too)
Adjust your up and down Zero and Full flaps with the end point menu,
You're done
good luck
Old 08-06-2011, 03:23 PM
frank99
My Feedback: (29)
why cant the book tell it like that one more question , have two servos of course can i use ch 5 and 6 and use switch c thanks a ton frank99
Old 08-06-2011, 03:30 PM
Goran619
Yes you go in the the AUX channel menu and assign the same switch to each channel.
Jordan
Old 08-07-2011, 03:44 AM
scale only 4 me
My Feedback: (158)
ORIGINAL: frank99
Like Jordan say,,yes,, but remember you'll have to set sub trims and end point for each independently.
Book tells you pretty basic stuff, But yes, it pretty much useless for programing questions.,I have one model Named "Test",, when I wonder "how can I do that" I go to the test model and start playing with things,, The more I play with things the easier it is to figure things out on my own. This being my third computer radio over 15 years I've developed a good Idea how the Futaba engineers think,, Don't be afraid to push buttons,, there is always that system reset button
The way I out lined is the simplest way, but not the only way,, multiple programed mixes could achieve the same thing,, but simple is good if you ask me
Also
I misspoke before "G" is also a 3 position switch if you prefer using that one
good luck
