Prop Hub
KY
Prop Hub
I have a Zenoah g-26. I have a trueturn prop hub and adaptor kit that supposedly will let me install this hub. I have tried every combination known to man and it can't be done. The hex head cap screw protrudes in every application. Can someone show me a schematic on how this all goes together? Thanks, Aframe2
My Feedback: (8)
RE: Prop Hub
My guess is that you're talking about a spinner, and you have a long screw but need a short screw. They sell them for an arm and a leg, or you can bring the screw down to Ace hardware or some other place that sells individual screws and find some shorter ones.
Maybe you can go on Tru-turn's site and find the size? They do sell spare parts. Once you know the size, can buy locally or even online for cheap.
Ok go here: http://www.truturn.com/cgi-bin/store...aparts&maxp=30
It's a 10-32 screw, but I forget if any 10-32 head will fit inside the cone?
RE: Prop Hub
I like the Ace hardware suggestion. Ace has thread gauges, so you just need to bring your cap screw with you. Use the guage to find the size, and then buy a screw of the proper length.
