Cylinder & Liner replacement
My Feedback: (18)
CA
Hi
Ive checked the price on piston & liner replacement for my OS .91FX and would like to know
if anyone has any info on replacement parts other than OS parts, maybe Magnum or ASP will
they work ?
Eddie
they work ?
Eddie
RE: Cylinder & Liner replacement
Not that I know of pretty much brand specific......out of curiosity why do you need to change the piston and sleve or is it the whole cylinder head?
My Feedback: (18)
CA
My engine has little to no compression and Ive replaced the liner and piston in an OS 46FX with no compression and it was like a new motor.
Im willing to listen if you have another idea.
the 91 fx is a ringed engine, you do not need to replace the liner or piston in a ringed engine (unless something terrible happened), you should replace the ring (search "frank bowman" he makes very good rings, better than factory)
