Reload this Page >
snow ski ideas for hobbico 60 trainer
Old 11-23-2011, 01:56 PM
bqy54
Default snow ski ideas for hobbico 60 trainer
Old 11-23-2011, 03:50 PM
fredsedno
Default RE: snow ski ideas for hobbico 60 trainer
Unless you are flying off packed snow,your'e probably better off building from scratch. I find any commercial skis are too small.
This is particularly noticeable on trike trainers. Engine down thrust really seems to bury the prop. fredsedno
Old 11-23-2011, 03:56 PM
bqy54
do u have any suggestions on size
Old 11-23-2011, 07:53 PM
42etus
42etus's Avatar
For a 60 size trainer on soft snow, I'd try about 4" wide x 14" long for the main gear skis and a little (75%) smaller for the nose ski. Just make sure that it can't reach into the prop.
Old 11-24-2011, 05:35 AM
mustangman177
These work good for me. Can make them what ever length you wish. Made from 2 1/2" PVC gutter pipe.
http://www.rcuniverse.com/gallery/ga...mberID%3D16901
Cary
Old 11-25-2011, 04:46 PM
Minnreefer
Minnreefer's Avatar
http://www.maidenusammp.com/ he makes nice stuff.
Old 11-26-2011, 01:53 PM
Deadeye
Deadeye's Avatar
I've used skis and I've used floats on the snow. Unless the snow is near perfect, floats have worked better for me.
Old 11-26-2011, 03:26 PM
Oberst
Banned
ORIGINAL: Deadeye
Yep, floats work the best on snow. On some of my scale planes I have used the Dubro Skis with good results. Me personally no longer fly in the winter anymore, I don't like snow blindness or numb fingers, so I'll keep the winter flying for the young folks.
Pete
Old 11-29-2011, 08:50 AM
captjckirk
Go with the floats. Be sure to balance the plane by putting the weight on the FLOATS. Then when you return to wheels the plane is already balanced for the wheels.
Old 12-03-2011, 01:22 PM
bqy54
going to build my own thanks for the input
Old 12-03-2011, 01:24 PM
bqy54
close 2 the ones i built thanks
Old 12-03-2011, 01:26 PM
bqy54
did not think about pvc went with basswood thanks
Old 12-03-2011, 01:30 PM
bqy54
dont want snow but better be ready thanks
Old 12-03-2011, 01:38 PM
MajorTomski
MajorTomski's Avatar
The dubro ski's work quite well on a Kadet LT 40 with a 46 on it. You just have to have the front of the skis locked about an inch above the back end when they hang free in flight. That's what prevents nose in in soft snow.
Old 12-03-2011, 04:15 PM
bqy54
how did u secure skis 4 correct angle
Old 12-03-2011, 04:17 PM
bqy54
Old 12-03-2011, 05:22 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
ORIGINAL: MajorTomski
Be sure and use loc-tite
Old 12-03-2011, 08:34 PM
bqy54
thats a start i will give it a shot thanks
Old 12-05-2011, 09:47 AM
MajorTomski
The dubro and most ski kits come with a spring that locks into a wheel collar that is how the nose of the ski is adjusted up or down.
Old 12-05-2011, 10:55 AM
scale only 4 me
My Feedback: (158)
3000 words
ID:	1695681   Click image for larger version
ID:	1695682   Click image for larger version
Old 12-10-2011, 09:21 AM
josh450r
I just finished my own set and am going for test flight right after work. I have a milling machine, lathe and drill press so it made it easier. I ended up copying a full scale design using aluminum and acable system using springs to hold the tips up in flight andfor landing, once pressure is applied to rear of ski the spring expands letting the skifollow the ground. Ialso machined in runners to helpthe ski hold its line. If anybody is intrested I can post pics and even make a set foryou, they don't come cheap though.The nice thing is I can make whatever you want as faras size or shape.
Old 12-12-2011, 04:06 PM
bqy54
computer been fried thanks 4 pic
Old 12-12-2011, 04:15 PM
scale only 4 me
My Feedback: (158)
scroll down to post #18 and on this thread we had last year,, this guys has a neat system I may try some day
http://www.rcuniverse.com/forum/m_10...key_ski/tm.htm
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
