Reload this Page >
Battery Charging
Battery Charging
Old 12-30-2011, 11:49 AM
aframe2
Default Battery Charging
I have a 6v 5cell battery hooked to a switch that I'm trying to charge. It seems the
only way I can get the charge light on my accu cycle charger to come on is to turn on the switch
that I have connected to the battery.
Do I have something hooked up wrong? Can someone send me a diagram of a battery
connected to a switch, connected to the receiver? Thanks, Aframe2
Old 12-30-2011, 01:30 PM
oldfrog
Default RE: Battery Charging
Sounds like you have the charging socket wired on the wrong side
of the on/off switch. If you're able, just change it around. It's working
the way it's wired now, but you're still supplying power to the receiver
at the same time.
Battery-Charge Socket-On/Off Switch-Receiver.
I hope this helps.
