cant find a manual
My Feedback: (15)
PA
cant find a manual
Hi all. I just bought a used thunder tiger .61 pro. I'm trying to find a manual for it. I went to the manufacturer's website and downloaded what it said to be the manual, but when I opened it, it was just an exploded view of the engine, and a parts list. Does anyone have an idea where I could go to actually get the manual? Thanks for any help.
RE: cant find a manual
If you mean the exploded view and parts list, along with the generic insructions how to run the thing, then it should come with the engine. If not, then 3 turns open on the main needle, run in on the ground at a fast 2/4 stroke break for 5 runs of about 1 minute each, then complete the process in the air. Set the midrange/idle after 10 min running time, do not run rich (4 stroking) or you will wear it out, do not run lean or you will wear it out, always 300~500 rpm rich from peak.
Evan, WB #12.
Evan, WB #12.
MI
ORIGINAL: tlojak38
tlojak38,
The Thunder Tiger site has allot to be desired. They show a picture of the manual in their manual section, but when opened it is for a plane. The manual is for all their pro series engines from the 25 to the 120. It has all the specs for each engine. I have it in PDF form and will PM you for your e-mail address and can send it to you.
