Glow Fuel Line "plumbing" Question
Has anybody used a three line fuel tank installation with the 3rd line (refueling line)connected to an external quick fill fuel valve? It would allow the line to the HSneedle to be a short and straight shot.
Comments?
Comments?
RE: Glow Fuel Line
Thanks Dave - 'preciate it.
What "brand" of valve do you use?
I've plumbed the fuel line (in a 2 line approach) between the tank and HS needle thru the side of the cowl with enough slack to allow pulling the line apart "outside" the cowl. A filter fits nicely too allowing for cleaning of the filter without removing the cowl.
RE: Glow Fuel Line
ORIGINAL: JohnGilmore
What ''brand'' of valve do you use?
I've plumbed the fuel line (in a 2 line approach) between the tank and HS needle thru the side of the cowl with enough slack to allow pulling the line apart ''outside'' the cowl. A filter fits nicely too allowing for cleaning of the filter without removing the cowl.
Then why the third line John? Fill the airplane at that point there is no need for a third line. I use two line systems on all my airplanes cowling or not and even my gassers.
John
RE: Glow Fuel Line
ORIGINAL: JohnBuckner
There is always an exception to a rule. If you only have a hammer then everything needs to be a nail.
RE: Glow Fuel Line
Also John one advantage of the external split carb line that you also used is in the case of a two stroke glow it gives you a very handy place to pinch the line for pinch tuning which one of the photos I posted illustrates.
Ya' see a hammer can really be a multi tasking tool
John
John
RE: Glow Fuel Line
John - Ithink that you're cowl "external fuel line"approach motivated me in using the same approach on my Aero-works Edge. Thanks.
My Feedback: (118)
TX
RE: Glow Fuel Line
I won't say which picture but that sure looks tacky (fugly) to have all that fuel line protruding outside of a beautiful cowl. Fuel dot (doesn't require hard pushing to get a filler adapter into) or fuel valve which can be mounted to a hard back so one doesn't compress and crack the cowl looks neat, proper and doesn't require butchering the cowl. If one needs to constantly pinch test their engine, fly w/o a cowl until she's tuned.
Now, on the other hand, having external visibility to a fuel line will allow one to check for bubbling and possible tank/hose leaks but that also is a routine maintenance issue and shouldn't have to be an every day checkup. A full cowl is a full cowl. It's painful enough to have to gouge it for exhaust, HSN and carb inlets the way it is. Sometimes it's about looks and the others is about convenience I guess.
RE: Glow Fuel Line
John
John
My Feedback: (-1)
RE: Glow Fuel Line
I use both the three line and a dot plus the split line like John. Just depends on the plane and my mood at the time. Two line split is the easiest to set up and most trouble free but I do use the three line more often, No good reason but it just works out that way?
My Feedback: (26)
RE: Glow Fuel Line
Your kidding. This and the two line system have been in existence for the past thirty years if not longer. Three line method is the way to go for both glow and gas. Fuel dots only inhance not distract from the appearence of the cowl. Don't invest in a chaep fuel dot get one sold by Sullivan.
RE: Glow Fuel Line
flycatch - I've seen fuel dot lines hanging out the bottom of cowls - flopping in the breeze. I've also seen fuel dots that are flush mounted in either the cowl or fuse side and are pulled out to affect refueling. How do you mount yours?
My Feedback: (-1)
RE: Glow Fuel Line
My Feedback: (-1)
RE: Glow Fuel Line
Also in the case of a completely exposed engine with rear needle valves there is never agine the need to use needlenose pliers every time you fuel when a simple split carb line is used
John
John
RE: Glow Fuel Line
ORIGINAL: Gray Beard
Known fact it would still look better with a fuel dot!!!
The only caveat in a fuel dot with 2 line plumbing for glow engines is that fuel when filling will hit the "tee" and travel in both directions, to the tank and the carb or pump. Carbs will flood and many pumps will allow just enough fuel through to flood just the same. For glow engines, it's better to have the fuel dot connected to the third or fill line. Also, the fuel dot should be placed higher than the tank to keep it from leaking as you remove the fill fitting
