OS .91 prop drive hub spins
My Feedback: (-1)
RE: OS .91 prop drive hub spins
ORIGINAL: big max 1935
you probably lost the woodruf key that goes in the crank & in the slot on the drive washer. Max
OK
I looked closely at the crankshaft and it looks like the key must have sheared off. It still has metal fragments in the slot it appears. Should I order a new crankshaft and drive washer with a woodruff key ? Or is there any other way to fix it.
Jim
The Woodruff key is made of steel - The drive hub is made of aluminum. Check the metal fragments with a magnet to determine where they might have come from. As long as the crankshaft is still straight and the drive hub keyway has not been enlarged, then all you will need is the key. I have lost these several times in the past - its easy to do.
My Feedback: (9)
I would take the glow plug out , put the drive washer back on with a prop , tighten it up good & see if it turns over ok . Did you have a prop strike ? Very unusal to shear the key .Maybe the metal in the crank groove is from the washer turning on the crank . One other thing is a liquid lock & it sheared when you tried cranking it . You may have more damage . Max
OK
I ordered a couple of keys from TH that are supposed to fit . Do you install it by putting the key flat side down in the prop hub and then slide it onto the crankshaft, then tap it in, or what?
My Feedback: (9)
It will come with a flat top & a rounded bottom. Make sure the crank slot is cleaned out very good . The rounded part goes in the crank . I would test it & the drive washer for fit & then what I do with mine is remove the key & put it back in with some RTV ,put the drive washer back on & your ready to go. Good luck , Max
OK
Thanks to everyone who posted.. It was a big help. Around here it is practically impossible to find a 1/16"x1/2" woodruff key, so I ordered some from TH. I checked at all the auto parts stores, and while they all had keys they were all too big! Thanks.. Jim
I've always used Lock-Tite and it has worked for me but it can cook out of a hot engine. RTV makes a lot of sense.
Dave
OK
Update:
Well, I ordered a Woodruff key from TH, and installed it on the crankshaft rounded side down, then slipped the prop drive hub over it and was able to rotate it so I thought OK, this is fixed. But when I put the prop on it and tightend it down, it kept slipping, so I tightnened it a little more and then the crankshaft wouldn't rotate at all! I thought maybe there was something wrong with the prop drive hub, so I ordered another one.If that doesn't work I guess I'll send the engine in and have it checked over.
My Feedback: (9)
You should have a spacer between the front ball bearing & the drive washer, if gone the drive washer will rub the front of the crankcasse & lock it up. you must have lost it also . May find one that will work at a good hardware store it needs to fit the crank & hit just the inner race of the bearing only. Max
