Covering Question
My Feedback: (17)
Covering Question
When covering a wing, do you press the covering to the rib cap strips like you do on the perimeter of the wing, or do you shrink it tight and let the material conform to the rib. The last plane I built, I pressed the covering to the cap strips with the iron, but didn't like the appearance.
Chuck
Chuck
RE: Covering Question
You do not have to press the covering to the rib cap strips. "Nail" it down on the leading and trailing edges with your iron plus of course the tips and root area. Hit the rib area with your heat gun to shrink it up nice when your all done. BTY, I have found that if the ribs don't have cap strips they are too weak to press down much with the iron without risking damaging them.
If you do not seal the entire film to balsa surfaces as a last step then the wing will not be up to design strength.
This is especially so on some designs such as trainers and others that do not have a sheeted D tube section, The intended torsional strength will be severely impaired.
Some folks don,t like to cut holes to let cooling air in and out of cowlings either because they don,t like the look.
John
John
Moderator
To apply the film you tack it all around pulling it as tight as you can, then heat gun it smooth. Then the last step to just touch the iron to each rib to stick the covering down. You can feel the difference in strength immediately after doing this.
Rather than using an iron on the cap strips you can use a soft "mitt" along with the heat gun. Follow the heat gun with your "mitted" hand. This will accomplish the same thing without jeopardizing the surface with scratches. Yea, even if your iron has a cover on it.
