AMA membership
MI
AMA membership
It has been awhile since I had an AMA membership due to military deployment. Does a membership last 365 days from the day i renew or is it a calender year IE January 01 through December 31. Thanks
RE: AMA membership
Copied from https://www.modelaircraft.org/files/902.pdf
Membership ends each year on December 31, regardless of the date a membership application is received.
All membership benefits begin on the day of receipt at AMA Headquarters of a properly completed application and correct dues payment. If a magazine is included with the membership, it begins with the first issue available for the year after a correct current application and payment are received; it expires with the issue printed in December (which is dated January of the following year). Membership rates and insurance limits are those in effect at the time of printing. Actual cost of dues and amount of insurance coverage is subject to change. Any such changes will be noted at the time of membership processing so they may be accepted or not.
Applications received after September 15 will be valid for the remainder of that year and all of the following year.
Banned
RE: AMA membership
"carrellh, so if I renew now I will be good till December 31 2013?"
Usually the club will accept your 2013 membership for the last few months of the year.
Les
Les
RE: AMA membership
ORIGINAL: devil505
Clubs vary. Our club does not charge dues for current year if a person joins after July 31.
