Help Required
Old 10-17-2012, 08:16 AM
SAMCPAKISTAN's Avatar
Default Help Required
<span style="font-family: Arial;"><span style="font-size: small;">Dear Guys, Best wishes for you. we need some help regarding electronic setup.
we have made a model of C-130 with depron sheet of 6mm, it's details are as follows :-
Wingspan 54"
Fuselage 40"
Motors E-Max 2210 Qty 4
ESC Flight Max 30A 4
Batteries Thunder Power 2500 mah 2
Now need about its seup, either to use 1 Y lead for two motors &amp; other Y lead for two motors ? or some different setup may helpful ?
THANKS.
</span></span>
Old 10-18-2012, 04:06 AM
Default RE: Help Required
As no one has given you an answer, why not post you question in one of the Electric Forums, http://www.rcuniverse.com/forum/default.asp?forumid=227 . I have no experience with more than one motor.
Old 10-18-2012, 05:47 AM
You need a separate ESC for each motor.
You can run all of them off of one battery.
Good Luck,
KW_Counter
Old 10-19-2016, 06:52 AM
Any heli guy can give me some idea ?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
