carb covers?
carb covers?
whats a good way to cover the venturis on the smaller OS engines ie 46 52 etc.. Ive tried the plastic slider cups for furniture,,but all seem to be just a tad to big or small,,is there something you guys are using,,also want to cover the mufflers on said engines,,Ill be storing them for a while and will be using ARO while they sit,,,,any suggestions?
thanksTAZZZZ
thanksTAZZZZ
RE: carb covers?
Try some of those foam ear plugs from one of the "home" stores. Scrunch (roll) them up, insert into venturi or muffler outlet, and they expand to seal the opening. Works great, one size fits all, and cheap!
RE: carb covers?
Vacumn caps from the local Napa or any auto store. There usually is a wide selection and you can get what sizes work without all the others in the selction packs.
I don,t normally use them on carbs but I do on occassion pickup nice thick rubber ones for the glow ignitor. I'am always loosing those
John
John
My Feedback: (-1)
RE: carb covers?
Pretty much all of the above. I have bought the assorted sizes of the auto vacuum nipples and used them. I get the ear plugs free at wood stores and used those. The wadded up piece of paper towel is great, one size fits all and if you forget to remove it from the muffler it just gets spit out when starting. Never have used the Exacto blade cover.
