hair spray a sanding sealer
TN
hi, i am fixing to start covering a dynaflite pt-19 with 100% polyester dress lining and polycrylic. was wondering if i could use aqunet hair spray as a sealer first since it is a laquer, to seal the wood
thanks.
thanks.
RE: hair spray a sanding sealer
The price is cheap if you get it at a dollar store. I've used it for years to help activate the adhesive on covering, especially if I'm recovering an old airframe . It also helps seal when there is some oil soak, that is if you got most of the oil out first. Kitty litter, electronic cleaner, baking soda or what ever you use to get the oil out . ENJOY !!! RED
My Feedback: (-1)
ORIGINAL: sensei
Some guys use it to seal the balsa wood before covering with Monokote or Ultra Coat.
Bob
Bob
I have used it myself..you want the cheap hairspray....sand smooth then a light coat....helps the covering iron down better as well...works like a charm
Hi Gray Beard
What do you use to apply the sanding sealer? A brush (conventional) or an air brush spray? Do you thin it down first or apply straight out of the tin?
I have a cub which I have been building for about 10 years (no joke) and it is at the stage where I need to paint the cockpit. I tried applying primer but it has gone powdery and I am debating using a sanding sealer - after cleaning of the dud primer before adding the topcoat.
Andrew
Andrew
ORIGINAL: Gray Beard
As a sealer?? Probably no? I do keep a big can of the really cheap lacquer hair spray in my shop to do as sensei said before using covering. Usually a recover in case there is still a bit of oil on the wood. The hair spray melts/softens with the irons heat and gets the covering to stick really well. For sealer I use Deft Sanding lacquer sealer and it will seal the wood and if you need to you can add an extra coat or two so the wood grain is filled. I use the deft to glass with but on a plane just getting covered with plastic film there is no reason for it. It too softens with the irons heat but it adds more weight then just a mist of hair spray. I have never tried it with the dress lining. Sense the advent of Solartex I haven't used silk or dress lining.
ORIGINAL: sensei
Bob
Bob
Bob
IN
And if your build is getting frustrating, just put an ignition source between Aquanet and your bird and you can start all over again. A buddy of mine tried a number of fuel sources for his PVC potato gun and found Aquanet to be the best propellant!
My Feedback: (23)
ORIGINAL: kitman09
thanks.
thanks.
yes you can.
My Feedback: (-1)
ORIGINAL: Andrewmc
Hi Gray Beard
Andrew
Hi Gray Beard
Andrew
I also never seal the frame with real sanding sealer if I'm going to use covering.
I use deft Sanding lacquer Sealer to glass my planes instead of resin is all.
I do not use the water based sealer and I use it full strength right out of the can with a brush. About 80% of the chemicals in it gas off so there isn't a lot of weight left behind. I do brush on two coats onto the bare wood then sand before I start to lay on the glass. It's just to keep the glassing coats from absorbing into the wood and being wasted.
My thinking is a sealer is supposed to seal up the wood pores and make the wood smooth so I think the hair spray wouldn't make a good sealer. It does really help in holding covering onto the wood. I'm trying to remove the covering off of my old pattern plane that someone used hair spry on the wood and it is really hell trying to get it off.
The Deft will fill in the wood grain and probably hold down covering too? I'm just not sure, I have never used it on a plane getting covered? If you want to use it then paint make sure the paint you use is lacquer based!!!
ORIGINAL: ma_mulcahy
Dave
The intent of using hair spray is to aid in adhesion, not to seal the wood. Lacquer based hair sprays are sometimes used as substitutes for products such as Balsarite.
I only use hair spray if I am covering with Solartex, Monokote, etc, whic alreay have a heat activated adhesive. I would not use it with any product, such as dress lining.
ORIGINAL: TomCrump
Bob
Is slick a good thing ?
When I sealed balsa, before glassing with Poly C, I ran into adhesion problems between the two components. The Poly laid on top of the sealer, instead of penetrating the wood.
The OP doesn't state how he plans to adhere his dress lining to the airframe, but to me, the idea would be to create a composite. The lining is placed over the wing, and whatever adhesive is applied over it, soaking through the lining, and into the wood. This makes a nice, strong bond. Creating a barrier, by sealing the wood, could easily weaken the process, by not allowing the adhesive to penetrate the balsa.
I may be wrong, Bob. These are just my observations.
I have used Stits covering system on all the full scale airplanes I have built over the years as well as some models, if there is any areas that are not open bay areas and are sheeted instead, then I used 3/4 oz. class and Poly C in those areas and overlaped onto them about 2.00" with the Stits covering system and finally prime and topcoat. Now if I am going to Monokote an airplane then yes the slick balsa finish is better for me because I strive for a 12" stand off show quality finish on all my builds and everything under a plastic covered airplane shows.
Bob
Bob
TN
thanks tom, i plan on using the poly to adhere the dress lining to the frame. so you dont use a sealer when using poly. this dont warp the wood frame.
