cold batteries?
cold batteries?
I store most of my batteries in my garage,,which is pretty cold in the winter months,,,,do charged batteries sitting in the cold lose their charge faster than if stored in a warmer area? If so Ill bring them inside,,or does it make any difference?
TAZZZZ
TAZZZZ
RE: cold batteries?
The batteries will take longer to charge, will store less capacity. It would be better to bring them inside for 24 hours and get to room temperature before charging. If they are Lipo's I would not even think about it unless you are there to supervise/monitor the charge cycle.
just my 2 cents...
just my 2 cents...
RE: cold batteries?
The cold slows the chemical reaction that makes batteries what they are. A friend crashed a small plane that the radio used dry cells. Brand new cells but left out in his truck overnight and put in the radio at the field. When everything warmed up after the crash during the crash investigation, it came back to life. Charging cells does warm the batteries; I still use wall warts so they can be still plugged in before I load the car. I would be more worried about dry cells than rechargeable.
RE: cold batteries?
In full scale all batteries are stored in a cold room. But will be room temp before use. So to store your batteries in the cold(above freezing) will not harm them. Make sure you let them warm before charging, and charge before use
