Futaba 1024 PCM receiver
RE: Futaba 1024 PCM receiver
No damage to the receiver but could possibly do some harm to a servo should any noise or extraneous signal cause one to go to the extreme position. That is not likely to happen but it is a possibility.
My Feedback: (40)
NE
I recently set a plane up with the 1024 pcm and everything worked fine. A couple days later I dicovered the switch was left on and had no response. Installed a different receiver and all is well. Coincidence maybe.
Dittos to Davids remarks about destroying batterys by leaving switchs on and have contributed far to many of my share but never affected any receiver of mine but I do beleve stray RF noise depending upon the severity of that noise could indeed affect a servo being over driven and damaging gears. A simple manual check of the gears would resolve those fears.
John
John
