noise reduction on gas engines planes.
QC, CANADA
Hello to everyone.
I'd like to get suggestions on cutting down the db's on wooden airframe
My question is concerning 2 strokes gas powerplant.Like my DLE20cc per example.
Available mufflers for this engine that cut the noise seem to be hard to find.
Please no electric solution.
My Feedback: (-1)
RE: noise reduction on gas engines planes.
Check with Brison mufflers, I think they have a nice one for the DLE 20 and it is a real muffler, not just a can with pipes. A lot of the noise people think is from there engine is from the prop too, something else to think about, the prop brand and shape can be louder then the engine noise.
QC, CANADA
Thanks for the reply Mr,Gray beard!
i just emailed a message to bisson to ask what i should expect from there muffler.
Since my engine with a xoar 16-6 at 8300 rpm is screaming 89 dbs.
I was thinking about a apc prop also.
maybe soft mounting the engine also but dams they are heavy those engine mount!
My Feedback: (-1)
I think I saw the Brison in the Tower Talk I got last week? I use there mufflers a lot on glow engines and they work great. I use the Xoar props on my gassers and find them quiet but it's hard to tell, I use the Jtec mufflers on my gas engines and they are just cans with no baffling. Where I fly we have no noise issues. I have never soft mounted a gas engine other then with the Dubro anti vibe beam mounts and never noticed any noise drop with them? I really never think much about it though so they may help?
QC, CANADA
Here we have quite an issue with the noise at our club.
I remember that a wood airframe act just like a drum in raising the noise of a plane.
i actually never try something like a soft mount for reducing the db's but if there sold i believe them to be effective.However i never seen a bird equipped with such a mount.
But i do remember that a friend of mine as bought a new Harley a few years back and he was amazed how much smoother and quieter his bike was.(he had the oem mufflers on it of course)
i will look into it even more.
It is Bisson as in "Biss Un." www.bissonmufflers.com
Good mufflers and Tower sells some of them.
My Feedback: (34)
I picked up one of these for my DLE 20 and it took a lot of the 'bark' out - along with a three bladed 15/7 prop
http://www.troybuiltmodels.com/items...0SILENCER.html
ORIGINAL: BarracudaHockey
Cannisters are quietest on a gasser.
Also a proper prop turnning a lower RPM to keep the prop from ripping
Bob
My Feedback: (29)
I would think that with the DLE 20 you could use a full tuned pipe. This would be better then the stock muffler and most airplanes that one would want to put the 20 into may not have room for a canister. The use of a soft mount would be high on my list of things to quiet the airplane. When one gets up to this size and larger, wood props seem to be the loudest.
ORIGINAL: Gray Beard
Bob, do you think the time and cost of installing them on a DLE 20 is worth it though? I haven't seen anyone do it yet.
Gene
Gene
Bob
My Feedback: (118)
TX
Would those quieter mufflers cut down much on power? That probably being a moot point beause it his plane is too noisey to fly, he's not enjoying this hobby much sitting in the bleachers.
I have a DLE-55 with a 23x10 prop and Bisson muffler. At a distance it is hard to hear the engine running. I have even been asked if I was running a canister at times. No complaints on performance (3D-capable airplane).
No, I don't work for Bisson.
QC, CANADA
My dle 20 is mounted in a Aeroworks extra 300 60/90.As far as power i have plenty so a slight cut in the power output is something i can live with.
Tuned pipe and canisters are not easy to install due to the size of the bird.
What buggin me is that i have a saito 120S waiting on the bench and that that the firewall has been trimmed to fit the rear carb its gonna be a mess to fit the Saito.
GOING TO FLY AT ANOTHER CLUB IS REALY IN MY MIND...
WY
I dont use 6 pitch props all they do is scream and the xoar props are #1 in my book and I only do wood props just incase of a ground strike god forbid,I'd rather break a prop than a crankshaft.just my 1.99 cents worth.
My Feedback: (49)
I have noticed at our field Arizona Model Aviators Mesa AZ that the dle 30 are perceptibly louder than the 20's or 55's Have a friend that placed 3/8 ID copper pipe with specially made washers pressed on to the copper pipe that slipped into the exhaust pipe on a very loud US 41 Gas motor and it quieted it down considerably. Top end suffered some but the plane was over powered anyway. There many ways of quieting Gas motors. Another one i saw on a large stinger the guy just used a header and strapped a tuned pipe to the bottom pf the plane ... doesn't look that bad (for a stinger) and dropped the sound way down.
My Feedback: (48)
I've got a DLE 20 which I really like EXCEPT for the annoying bark it produces. I'd be more than willing to sacrifice some it's performance for some peace and quiet. Anyone know of a canister/header that fits this thing without a lot of modifications?
My Feedback: (34)
It works....and it only costs $20...and don't forget about going to a three-bladed prop!
QC, CANADA
i tried the stinger from troybuilt and it does work but not my expectations.
i have a deal pending for swapping my dle for a o.s surpass 91.
i know that 120 would be preferable but it should be good.
My Feedback: (-1)
ORIGINAL: 757jonp
