Reload this Page >
BALSA USA PHAETON 90
Old 02-02-2013, 07:09 AM
seniorspud
My Feedback: (69)
Default BALSA USA PHAETON 90
HI WAS WONDERING ABOUT PUTTING AILERONS ON THE TOP WING OR JUST MIX AILERONS AND RUDDER NEED SOME HELP THANKS CHICK
Old 02-02-2013, 06:48 PM
Edwin
Default RE: BALSA USA PHAETON 90
I did it on mine. Servos on the bottom wing, connecting rods on the aileron trailing edges. Worked like a champ. I flew mine with a saito 1.20 at 14lbs. Did great slow aerobatics. Lots of lift and landed even better with -1.5 deg incidence on the top wing. It would land at a walking speed. My Ziroli stearman doesnt have ailerons on the top wing and still rolls pretty good, even faster if help it with the rudder. The ailerons on my stearman are much larger than what the P90 has. I dont like the mix idea because it might affect other maneuvers I might want to do.
Edwin
Old 02-02-2013, 07:48 PM
AA5BY
I didn't but if building another... would do as Edwin did.
Old 02-02-2013, 08:06 PM
seniorspud
My Feedback: (69)
HI WHAT SIZE AILERONS FOR THE TOP WING I JUST FINISHED A 10-300 WITH FOUR AND IT FLU GREAT THANKS CHICK
Old 02-02-2013, 08:16 PM
Sourkraut
Sourkraut's Avatar
ORIGINAL: Edwin
Edwin
I built mine with only the bottom wing ailerons, it does roll OK but would have benefitted from top wing 'rons I am sure. If I were to do it again, I would add them to the top.
ID:	1847355   Click image for larger version
ID:	1847356   Click image for larger version
ID:	1847357   Click image for larger version
Old 02-03-2013, 06:00 AM
Edwin
I did 1.5" wide strip ailerons on bottom and top. The trailing edge of both wings were, I think (this was a lot of years ago), were about 3/8 to 1/2. I used dubro plastic flat hinges. A guy in a local club has one for sale.
Edwin
Old 02-03-2013, 07:16 AM
jester_s1
Moderator
I have an old Phaeton .40 (not the Phaeton II) that is all stock, and I find the roll rate to be fine. I fly it scale like and do basic aerobatics with it. As it is set up now, it does a full roll in about 3 seconds. I have more travel available if I want it, but I'm happy with it as it is. If you want it to fly like an Ultimate Biplane so you can do 3D with it or just have the 1 second and less roll rates, then you'll need the top ailerons. But if you want it to look like a real biplane in the air, the stock setup is plenty.
