JR DS362 Voltage
JR DS362 Voltage
Hi Guys,
I am using a JR DS362 servo on throttle, which is currently regulated to 5.6 volts as i am using a Li Ion battery.
I am considering changing to LiFe batteries and would like to know if any one is using this servo on LiFe's unregulated, without any problems.
Thanks for any advice given.
RE: JR DS362 Voltage
I have been using Duralite Li Ion's for years and will continue to do so. In my pattern ships i am using a 4600mah 4 cell pack because of the redundancy. This pack weighs 216 grams, which i can get 15 flights from on one charge. I am trying to reduce weight and for competition only need to get 2 or 3 flights from the battery. 2 X 700mah LiFe batteries, weigh less than 100 grams and can save the weight of a reg as well. I also will still have the redundancy.
I have been having trouble finding voltage specs for this servo.
