Reload this Page >
pull-pull cable strenth ?
Old 09-20-2003, 06:25 PM
vasek
vasek's Avatar
Default pull-pull cable strenth ?
is the du-bro 4-40 pull-pull system cable strong enough for the ruder on a .60 ultra stick?
it doesn't say the cable strenth on the package...[>:]
thanks for helping,
vasek
Old 09-20-2003, 08:28 PM
Rcpilot
My Feedback: (78)
Rcpilot's Avatar
Default RE: pull-pull cable strenth ?
I'm not sure if your talking about the Kevlar or the steel cables. IMO either will be plenty for a 60 size stick.
Most Kevlar is rated around 100 pounds, and I think the .032" cable would be well above that. If it's the .015" cable, then I might be a bit scared. It would probably be fine- but I tend to go a bit overboard on stuff like this.
Old 09-20-2003, 08:36 PM
vasek
vasek's Avatar
rc pilet, it is a nylon coated cable, it doesn't say it's size...
Old 09-21-2003, 09:52 AM
Rodney
Anything rated over 30 lb.s should be more than adequate. I use lots of 20 pound test fishing line on very large models. After all, you do not want to tear the moveable surfaces off their hinges.
Old 09-21-2003, 11:47 AM
vasek
vasek's Avatar
good point rodney, thanks
Old 09-21-2003, 04:38 PM
Strat2003
I've used the DuBro coated cable on my Boxer 60 and it's worked fine for three years. I've also used the Sullivan kevlar cable on an O S .91 four stroke powerd Chipmunk with good results for twice that long.
Old 09-22-2003, 12:17 PM
greenboot
I've had a cable break but the problem is at the attachment. If it is kinked or a sharp corner rubs, it will break. The cable itself is plenty strong.
Tom
Old 09-22-2003, 09:27 PM
huggins
huggins's Avatar
It will work. I have been flying a Goldberg Ultimate w/Saito 150 and 2-56 Dubro pull-pull kit on the rudder for 3 seasons. No breaks yet! Keep in mind that a 100 oz-in servo (probably bigger than what you are using) with a 1" arm will only generate 100 oz of pull which is 6.25 pounds. As pointed out by greenboot, sharp corners where abrasions can take place is the killer.
