Are my batteries sufficient
OK
Hey Gang
I bought a 84"Eagle trainer that is made for a 26gas engine. I bought3305futabaservos for the rudder, ailerons and the throttle . I also bought Futaba 3010 metal gear servofor the elevator. My question is, will the battery pack that comes standard with the Futaba 6ex be enough to power these servos for a sufficient amount of flying time?
RE: Are my batteries sufficient
If you are referring to a 4.8 volt 600milli-amp NiCd pack I would say no if using those servos. Seems they like to draw higher current and if that pack is not operating 100% then you may only get one flight. I would get a larger NiCd pack around 1500-2000ma . If you can't find a larger NiCd pack and have to get a NiMh then I would put in a 2500ma NiMh pack. As stated if you are installing a gasser you may need to move weight around and a larger battery pack will allow this.
I am in full agreement with Big Max and FW above but if your 6ex system is the 2.4 version and you are using four cell (4.8) flight pack then you need to convert to five cell (6) volt packs and for that airplane as FW noted at least 2000mah's.
I highly recommend that 2.4 only be operated on (6) volt packs which would be five cell packs if Nicd or Nimh.
Just an opinion
John
Just an opinion
John
