Small aluminum plates
My Feedback: (8)
KS
Does anyone know where I would be able to find a small aluminum plate? I need one that measures approximately 1 3/4 inch X 1 3/4 inch X 1/8 inch. I need it to replace the warped carb adapter plate on my RCS 1.40. I won't have trouble drilling and tapping the 5 small holes to attach the plate and allow for the carb pressure hole, but I might have trouble drilling the 5/8 inch hole in the middle... I think I can do it with a hand drill if I had the right sized drill bit though.. It doesn't have to be perfect.
Any ideas? I've got a dremal tool, a drill, and a vise to work with here. Or, where can I get one made at? I'm trying to find the price of making one, buying one, or buying the stock part (if I can).
HI
RE: Small aluminum plates
RS2K
As for Material, if you can find a sheet metal shop in your area they will have a scrap bin around somewhere, and if you ask nicely they will probably give you a piece that size for nothing. One thing though, when drilling small aluminum pieces like that use the vise to hold the work. If you hold it in your hand and the drill binds up in the aluminum you can get a really nasty cut or worse.....[:@]
Bill Sindel
Bill Sindel
