RCG-20 gas Engine problem
AR
Purchased a HobbyKing RCG20 EI gas engine 6 months ago and installed it on a BigStik 60. Started ok on the ground using a 12 oz sullivan tank and seems ready to run. Took off and engine died in mid air. Found air bubbles in line. Checked lines/tank for leaks....tested in water and none found. Took off and quit again......replaced tank with a 8 oz and 3/32 line......thinking that the tank size was too tight for the 60 plane causing foaming. Took off and quit again in the air. Seen no air bubbles in line, but still quits in the air. You can start it and rev it up with no problem on the ground ....take off ok and get about 100 ft and engine starts popping like air bubbles and then quit. It seem that it quits banking at around 20 deg turn to the left. I can remove the tank and mount it on the top of the wing....run it on the ground and shake the tank and runs ok. I have tried a felt chucker to see if it will correct the problem.....no fix.
Has anyone had any problems like this before?
Uses 25:1 oil mix.....93 octane gas......apc 15 x 8 prop
Grif
Grif
My Feedback: (-1)
RE: RCG-20 gas Engine problem
Bubbles would be the fuel lines either in or outside of the tank. First thing to do with any of the engines from China {including DLE} is to toss the no name plug and replace it. I have seen those Chinese plugs arc everyplace except the electrode. Other then that it would just be the tune.
