Saito 150
Old 07-08-2013, 10:23 AM
ejames7699
My Feedback: (18)
Default Saito 150
I have a Saito 150 and the cylinder case has to be replaced because of the muffler ripped out during a crash. The cylinder has to now be replaced and I'd like to know if there are any special tools needed to remove the valve spring retainer or exactly how's the best way to do it without damaging the springs or valves. There are little clamps holding the valves on top of the springs that I'm concerned about.
Eddie James
Old 07-09-2013, 06:51 AM
daveopam
My Feedback: (9)
daveopam's Avatar
Default RE: Saito 150
Eddie, I can't help with your specific question. But did you know that Clarence Lee can repair your cylinder head? If you have already purchased the new head than there is no need for further discussion.
david
Old 07-09-2013, 07:18 AM
ejames7699
My Feedback: (18)
How do I contact this guy ?
Old 07-09-2013, 11:07 AM
bob62
My Feedback: (28)
bob62's Avatar
Look in your AMA magazine he has a add in the back
Old 07-09-2013, 03:39 PM
daveopam
My Feedback: (9)
daveopam's Avatar
"Look in your AMA magazine he has a add in the back"- exactly
I have seen his # and address in the glow engines forum, but not sure on which post. Maybe you could search the forum using his name?
David
Old 07-09-2013, 04:02 PM
bob62
My Feedback: (28)
bob62's Avatar
Lee Custom Engine
818-352-3766
Old 07-09-2013, 06:19 PM
ejames7699
My Feedback: (18)
I really do appreciate that and thank u very much
Old 07-09-2013, 06:58 PM
Gray Beard
My Feedback: (-1)
I have a YS 110 I bought used that was in a crash, not sure if the damage was done in the crash or the header was torqued into the cylinder too tight or if it was loose and vibrated but Mr. Lee did the repair on the engine. Outstanding repair job and I have been using the engine for two years without a problem. He also repaired another one of my engines that I over torqued the regulator screw on, 10 years later and it is still working great.
Mr Lee taught a bunch of us kids to tune an engine when I was about 13 when he was still designing the K&B engines. Very nice guy.
To repair the YS he drilled out the old threads and installed a brass nut with the standard header threads on the inside. I think the threads in the nut are much stronger then the stock aluminum threads.
