Reload this Page >
Control horn backing plate
Old 01-16-2014, 05:18 AM
Aug
Aug's Avatar
Default Control horn backing plate
If you had to make a backing plate for this control horn that will be for the ailerons on a 20cc size plane, what would you use for the material?
Old 01-16-2014, 06:10 AM
jester_s1
Moderator
Are you talking about something to go on the outside of the covering on the other side of the horn or something to replace the balsa wood in the surface itself?
Old 01-16-2014, 07:58 AM
jetmech05
I wouldn't...the plastic horn with the plastic backplate the screws bite into the back plate. The horn you have uses wood screws and glue to bite into the wood of the control surface. A drop of glue on the screw will be good
Old 01-16-2014, 10:06 AM
Aug
Aug's Avatar
Yes it will go over the covering material. I thought of plywood but too much work. How about cutting it out of an credit card type material? How about cutting it out of an old CD?
Old 01-16-2014, 12:17 PM
JohnBuckner
JohnBuckner's Avatar
I would go ahead and use it with a back plate. I of course have used the type that is glued & srewed but just never felt comfortable with them and have experienced failure with both but the difference is I have never experienced the backplate type completely separating but have the glued & screwd.
My first choice would be .050 or less aluminimm but realize you likely don't want to use that so my next choice would be 3/32 birch ply. The reason why I don't like the plastic cc card is it is not as thick a normal control horn back plate and a more brittle plastic material. Remember you may experience more vibration with this 20cc gasser over the glow or electric stuff.
John
Old 01-16-2014, 02:31 PM
Aug
Aug's Avatar
Got it. Thanks. I'll stick with the plywood.
Old 02-05-2014, 09:46 PM
A. J. Clark
A. J. Clark's Avatar
I had the same situation with a nylon horn where they supplied wood screws.
I used a strip of brass on the back side with #2x56 screws run from one side
through to the other. The nuts were on the bottom where they couldn't be seen.
Old 02-06-2014, 03:52 AM
Aug
Aug's Avatar
Thanks. I didn't think of using a nice thin sheet of brass.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
