smoke systems
BC,
smoke systems
I fly a big model Stearman with 91 FS pulling it around, its a wonderful showplane but smoke smoke system would be the finishing touch ,any info on availablity will be apprecaied Mike
My Feedback: (158)
My no pump smoke system...
Y off the muffler pressure to presurize the smoke oil tank, you'll need a check valve inline too
Dubro sells a simple servo operated pinch valve
You'll want to tap and install a nipple right in the middle of the exhaust header, no in the muffler itself
Simple ,, good luck
Simple ,, good luck
