Resin
My Feedback: (28)
With thanks for the comments, got a spoon full and a little aceton and mixed it up. It turned the right color, them mixed some hardner with it but it will not setup. In the garabge
I would expect your results, following your procedure.
My Feedback: (29)
At this point we don't know if it is epoxy resin or polyester resin. Personally I have never seen polyester resin go bad. Its hardener MEKP can and does go bad. Being that the resin has gone cloudy I'm going to assume it is epoxy. I agree with Tom that any additives must be added in after the epoxy/hardener have been mixed well. Acetone is usually not used for thinning epoxies. Usually 98% Isopropyl Alcohol is. It's always best to cure any epoxy at 70 degrees or slightly higher.
My Feedback: (28)
OH
Several years ago Dave Brown commented that resin that crystallizes can be restored by heating in a microwave for a few seconds. He also commented that only the better resins have this problem due to high solids content. Remember, he sold this stuff and should know.
I've often heated thickened resin and had no problems with the epoxy curing.
My Feedback: (29)
I've not heard that before. During my classroom training I was taught that it was because of contamination, moisture or improper storage. One of the reasons the Aerospace industry sets an expiration date one year from date of manufacture or delivery depending on the actual product. Will it work for the purpose of an R/C model? Most likely yes.
